| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: why is ballast resistor not needed?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| JMOR
01-18-2013 08:19:09
72.181.173.171
Quoting Removed, click Modern View to seeThe association should not be 'round' or 'square', but rather the coil's primary resistance. Primary resistance (added to ballast resistor if such is used) determines the coil primary current. The general intent & end result is to have that current be about 3.5 to 4 amperes. Voltage divided by primary resistance equals the primary current. For example, let us say that running/charging voltage is 7.5 volts & typical square coil is 1 Ohm & ballast is 1 ohm (warm), then primary current is 7.5/(1+1)=3.75 amperes=good.
Then do same for 1.6 Ohm round coil and we see 7.5/1.6=4.68 Amperes= a little high, but within reason and just about where the 8N side distributor models run. |
| kylemorley
02-03-2013 07:20:02
96.61.89.69
Re: why is ballast resistor not needed? in reply to JMOR, 01-18-2013 08:19:09
| Spark coils don't like too much voltage, so most 12V or ballast- less 6V coils do have the extra resistance, but it's built into the coil. There is no advantage to running a 12V coil rather than a 6V with a ballast. Some cars use a resistance wire that acts as a ballast resistor woven into the wiring harness, which can be real confusing if you are doing an engine or harness transplant and leave it out. BTW the fact that a ballast changes resistance as it heats explains why some tractors will start immediately or not at all - the heating of the ballast resistor combined with the drop in battery voltage can quickly degrade the voltage to the coil down to the point where it can't produce an adequate spark. This can be a special problem when for some reason the coil is overballasted so it is putting out a marginal spark in the first place. So, if one is playing with non-standard coils or ballasts it can really pay to make the extra effort to get the ballast resistance just right. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
