Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 8n split behind trans
[Return to Forum]
MI-B ill
01-16-2013 06:16:16
70.194.4.45
I am getting ready to switch rear differential/axles based on recommendations from this board. It appears that splitting the 8n behind the trans is a simple task once supports are worked out. Questions; what is necessary for reassembling. Prelims; pull PTO shaft? pull drop hyd. pump? pull side covers? Replace Gaskets. Any other parts likely needed? Thanks Bill in SW Mi
[Reply]   [No Email]
Hobo,NC
01-18-2013 16:22:52
71.30.81.18
 Re: 8n split behind trans in reply to HCooke, 01-16-2013 06:16:16
Overkill as usual... :lol: Look'n at the pix I may cut the crank handle off and weld a nut on it so I can crank it with a ratchet :idea: I had to move it forward so the crank handle would clear the fender...
[/img]
[Reply]  [No Email]
Hobo,NC
01-17-2013 04:41:20
71.30.81.18
 Re: 8n split behind trans in reply to MI-B ill, 01-16-2013 06:16:16
Had to go back and find that post... Its your call but it is a EZ swap to swap the trumpets as a assembly (No messing with axles, seals and brakes).. Either will depend on were and the equipment you have on hand to make the swap...
EZ way to split
[img][/img]
[Reply]  [No Email]
heybusdriver
01-17-2013 20:06:47
70.71.96.170
 Re: 8n split behind trans in reply to Hobo,NC, 01-17-2013 04:41:20
I would be interested in seeing exactly how that
tongue dolly is mounted to the tractor. Thanks
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
[Reply]  [No Email]
soundguy
01-16-2013 11:41:53
173.103.20.228
ditto what was said.. however I see no need to drop the pump.. unless you are swapping them..
[Reply]  [No Email]
showcrop
01-16-2013 06:24:36
75.67.231.80
Be sure it is level front to back before splitting makes it push together much more easily. Drain the oil. drive wedges in between front axle and front frame so that the front doesn't flop over.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
