| Ford 9N, 2N & 8N Discussion Forum |
Topic: 9n transmision drain
[Return to Forum]
| Author |
[Modern View]
| lrry
01-15-2013 13:05:03
66.252.91.206
I have a 9n i changed the main shaft seal and now i need to drain the fluid and change it the drain plug is chewed up so bad i can't get a wrench on it. there is another plug in the rear and a plug on the side of the housing that is a small plug will all of the fluid drain out through the plug on the back it would solve my problem if i could drain it through the other plugs i can get them plugs out of but the front plug is going to take some time.any info is greatly appreciated. thanks larry |
| heybusdriver
01-15-2013 19:43:24
70.71.96.170
Re: 9n transmision drain in reply to lrry, 01-15-2013 13:05:03
|   I had to weld a bar on mine , after it came loose , I just left an inch on bar for future use. |
| L. B,
01-15-2013 19:04:26
64.187.79.169
| A small pipe wrench with a cheater, it works better then a large pipe wrench this is where big is not better large pipe wrench will want to roll off bung or plug. Welding a nut is also a good idea. The chisel and hammer will work but that would be my last resort. |
| soundguy
01-15-2013 15:39:38
173.104.220.228
| | 2 bungs, 1 plug drain.. all ont he bottom. try a pipe wrench held up with a jack. if no.. then a chissle and mallet.. or even air chissle. or weld a nut to the bung head and use a real big wrench on it. |
| Bob Harvey
01-15-2013 14:36:06
209.121.225.232
| If it is the large drain plug, you could try an impact gun with a sharp chisel and lower than normal air. HTH |
| JMOR
01-15-2013 13:13:48
72.181.173.171
| Looking at cut-away, you can see why all 3 have to come out for a complete drain.
| old
01-15-2013 13:11:07
209.86.226.19
| On the 9N/2N/8N there is 3 drains one fill. Problem is you need to drain all 3 to get all the fluid out. One trick that some times works is welding a wash then a nut on to the plug so you can then get a wrench on it. Or a pipe wrench and a bottle jack and board so the wrench can not jump down and off. Also they only have the one fill place for the rear end hyds and transmission |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
