Wayne Fleury
Was warming up the 52 8n I noticed was not
charging. Shut off, turned back on, No Spark???? I
am going to take the 48 8n up north to our cabin
this summer so I thought I would make the 52
reliable. So, had alt checked out, ok. Replaced -
wire harness, ignition, distributor, coil,
carburator, diode. (carb was really bad). Is wired
12v and is wired correctly according to every
diagram I have seen. Everything clean, bright, and
tight. Flywheel set at 4 deg, spark plugs 1,2,4,3
ccw on dist, rotor pointing to front head bolt and
no 1 plug wire in right location. (also replaced
spark plug wires), I know I did not have any spark
before I replaced everything, but with everything
I could think of replaced I should. Diode wired
correctly. I have tried just about everything I
can think of. I have power to and from coil??? My
48 is VERY relieable and wanted to make the 52 the
same. Any suggestions would be helpfull....Thanks
