TractorLinks.com
Show Parts for Model:
Re: E15, most here know is bad.
Hobo,NC
01-15-2013 05:31:16
AAA Say's (They do blow a lot of hot air sometimes useless B.S.) They are somewhat correct this time :shock:
Key word here phase separation it does happen and not as uncommon as you would think... Its nuttin new and been around since the 80's in gas... This is one reason I will not buy from Joe blows cheapest gas on the boulevard...
Gaspump
01-15-2013 10:48:55
 Re: E15, most here know is bad. in reply to Hobo,NC, 01-15-2013 05:31:16
Phase separation is a big problem that the marine industry has fought since the early days of E-85. It can occur frequently and many people do not know that simply mixing non-ethanol gas with E-85 can be the cause of phase separation. When it happens the ethanol relases its entrained water, Gasoline releases the ethanol and now you have a big problem especially if fishing 30-100 miles offshore.
MisterT
01-15-2013 10:57:35
 Re: E15, most here know is bad. in reply to Gaspump, 01-15-2013 10:48:55
If you're fishing 30 to 100 MILES off shore, you are probably a commercial fisherman, and you boat probably has a DIESEL engine. If so, you shoukld probably NOT be using ethanol blended gasoline. :(
Gaspump
01-15-2013 17:27:42
 Re: E15, most here know is bad. in reply to MisterT, 01-15-2013 10:57:35
Yes fishing that far offshore is a commom thing here. No not all offshore sport fishing boats are diesel. Yes a lot of diesel sport fishing boats are built but most of the smaller like 27" and under are gasoline inboard or outboard powered. To find good offshore fishing here you need to be at least 35 miles out in the Gulf Stream and 50 miles to offshore rock formations. I have exceeded 100 miles on many, occasions both fishing and testing boats. Many boats in this class run 25-35 MPH so it is no big deal, 2-3 hrs out fish and the same back.
JMOR
01-15-2013 11:04:18
Quoting Removed, click Modern View to seeYou sure used a lot of probably's in there. :roll:
MisterT
01-15-2013 11:27:42
 Re: E15, most here know is bad. in reply to JMOR, 01-15-2013 11:04:18
PROBABLY because I'm not a fisherman.
TheOldHokie
01-15-2013 06:33:21
OEM's don't warrant their vehicles - including E85 flex-fuel vehicles - against damage caused by the use of phase separated fuel. As you note separation is already a possibilty when using E10 or E85 so that is not the warranty concern with the use of E15. The key word with regard to warranty coverage is corrosion.
TOH
JMOR
01-15-2013 06:58:14
 Re: E15, most here know is bad. in reply to TheOldHokie, 01-15-2013 06:33:21
Quoting Removed, click Modern View to seeI think it is a lot like milk.........fresh=OK, stale/old=bad. Maybe you could use old e-? to make biscuits? :roll:
TheOldHokie
01-15-2013 08:31:01
 Re: E15, most here know is bad. in reply to JMOR, 01-15-2013 06:58:14
Although the testing is incomplete I suspect sour Enn doesn't make good biscuits and probably not any good for your septic tank either ;-)
TOH
