TractorLinks.com
Show Parts for Model:
Re: E15, most here know is bad.
russb wa
01-14-2013 16:55:48
I don't exactly remember what got my thinking turned around to where I run the carb dry if there is going to be extended non use.
Stabilizer can't hurt, probably helps a lot.
BillM (OH)
01-15-2013 22:05:05
 Re: E15, most here know is bad. in reply to russb wa, 01-14-2013 16:55:48
I have been using E-10 in everything, since that's all you can get at the usual gas stations, with no problems so far as I can tell and have several engines that sit around unused for months. That said, I do add "stabil" to most of them and make sure to shake up the couple of two cycles I have before starting to make sure the ethanol hasn't separated to the bottom leaving the 2 cycle oil behind in the gasoline (I don't worry about the 2 cycle snowmobile that has separate oil feed). I guess about the only place you can get 100% any more around here would be the airport.
