Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: E15, most here know is bad.
mhb@ufe
01-14-2013 16:21:18
E10 has been causing a lot of problems in small engines for years (lawn mowers and generators for example) and the repair shops get grief from their customers because they have to keep bringing them in for the same problem. We advise people to use fuel treatment to prevent phase separation but some just think it is a sales pitch.
Mark
russb wa
01-14-2013 16:55:48
 Re: E15, most here know is bad. in reply to mhb@ufe, 01-14-2013 16:21:18
I don't exactly remember what got my thinking turned around to where I run the carb dry if there is going to be extended non use.
Stabilizer can't hurt, probably helps a lot.
BillM (OH)
01-15-2013 22:05:05
 Re: E15, most here know is bad. in reply to russb wa, 01-14-2013 16:55:48
I have been using E-10 in everything, since that's all you can get at the usual gas stations, with no problems so far as I can tell and have several engines that sit around unused for months. That said, I do add "stabil" to most of them and make sure to shake up the couple of two cycles I have before starting to make sure the ethanol hasn't separated to the bottom leaving the 2 cycle oil behind in the gasoline (I don't worry about the 2 cycle snowmobile that has separate oil feed). I guess about the only place you can get 100% any more around here would be the airport.
