For...: Carmine D. ......TSX241B #2 pic.
GB in MT.
[b:c4b976207b][i:c4b976207b]Carmine;
Finally got a half-way decent day, to finish up your second carb.!!! Been cold as a witches....BROOMHANDLE, here!!!
This one is slated for testing tomorrow....if the weather permits!!!??? Gonna use it on Hermie the 2N, to plow out my upper drive, if the temp ever gets up above 25deg. F.!!! :lol:
Was going to call you, but have misplaced your #!!???
ENJOY!!!.....:
Gary :) [/i:c4b976207b][/b:c4b976207b]
Have seen you say "gonna test on Hermie" so many times, GB. How often do you have to replace the carb to manifold gasket? LOL
(quoted from post at 19:08:22 01/13/13) Have seen you say "gonna test on Hermie" so many times, GB. How often do you have to replace the carb to manifold gasket? LOL
b:d37c960185][i:d37c960185]
Well, since you ask....I have some used ones that I keep on a nail, in the big shop, next to Hermie's stall, and when one gets bad enough, NOT to seal, I just throw it away and get another used one that works without leakin'.
"HOW MANY"?????? Depends on how many carbs I overhaul in a months time, and how bad the used gaskets are, sealing wise!!!!!!
Gary :shock: [/i:d37c960185][/b:d37c960185]
