Hi Guy"s I"m thinking about selling my 2N,it has a serial # on the block 100651 the block has been welded & it has been rebuilt in 2000. I have a 5" box blade bought from Tractor Supply in 2001 (used very little). It has been converted to 12Volt. Also comes with a set of disc, 8' Ford. The tractor needs new wiring brakes & paint. I have put a new rebuilt, hydraulic pump(from external_link), clutch pressure plate throw out bearing, rear PTO seal & bearings.Rear tires and tubes are new. I sand blasted the rims primed & painted before mounting the new tubes & tires.I have many extra parts both new & refurb. plus various manuals that will go with it. Any help will be appreciated. Thank you, Jay2NSC
