Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Rectifier Install and Generator Output
01-13-2013 10:28:50
Quoting Removed, click Modern View to seeBogus reading of the digital meter in an electrically noisy environment. Analog meter needed. A better reading at battery because battery acts like a BIG filter capacitor.
01-13-2013 10:55:25
 Re: Rectifier Install and Generator Output in reply to JMOR, 01-13-2013 10:28:50
I will see if I can borrow an analog one or maybe pick one up. If I am seeing the voltage at the battery increase from 5.7 to 6.7 or so with the engine running, is it likely that there is anything wrong generator wise?
01-14-2013 07:03:21
 Re: Rectifier Install and Generator Output in reply to 9n200460, 01-13-2013 10:55:25
slow sample rate on cheap consumer meter.
go analog like jmor said.
01-13-2013 11:26:24
Quoting Removed, click Modern View to seeLooks like generator OK & 6.7 will likely increase with longer run time. If battery begins to overcharge, remember that you have the HI/LO adjust on rear of generator to back it off.
