| Ford 9N, 2N & 8N Discussion Forum |
Topic: Re: Not really overkill
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| TheOldHokie
01-13-2013 05:56:43
74.110.73.253
An N is quite capable of running a lot of implements that require a hydraulic system of this sort and Ford provided similar setups for the NAA and 600 sereis tractors. The internal sump capacity is sufficient for this size pump with a couple caveats. First the 12 GPM pump rating is maximum output at 2000 engine RPM The flow rate is proportional to engine speed - e.g 8 GPM @ 1500 RPM, 6 GPM @ 1000 RPM, etc. You also need to consider the duty cycle of the hydraulic loads you are running. For example you wouldn't want to try and run something like a rotary broom tpowered by an 8 GPM hydraulic motor. The motor onteh broom has a nearly 100% fully loaded duty cycle and with that small a reservoir the oil would overheat from the constant high pressures. But you can run something like a loader that actually has higher peak pressure flow requirements but with very intermittent duty/load cycles that give the oil a chance to cool down between cycles.
The valve in the pictures controls two DA cylinders and requires 4 bidirectional couplers. So the coupler count is not as much about volume as it is function. Those are 3/8" couplers good for about 6-8 GPM each which is overkill for the customer's current application which is a front snow plow with power lift and angle. But because he wanted the flexibilty to run a small loader he balked at a smaller pump and 1/4" couplers. In fact he initially wanted four more front couplers to go with the rear ones but I talked him down off that ledge - at least for the time being ;-)
Next N-series hydraulic system on my schedule is a 16 GPM pump for a guy with a loader/backhoe. He will be using his existing 5 gallon external reservoir to up the overall system oil capacity to 10 gallons.
TOH |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
