Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: FEL Sudden drop under load ( update)
HCooke
01-12-2013 07:44:38
Because of the high pressure involved, I would use a ready made gasket (avail here at YT and other places). No gasket goop on that gasket either.
Mr. T. Minnesota
01-12-2013 10:34:49
 Re: FEL Sudden drop under load ( update) in reply to HCooke, 01-12-2013 07:44:38
HC,
Checked the parts department and found the gasket set. What am I going to do with all that mat board stored in the shop?:):) Thought about inserting a modified copper grommet into the oil port opening of the gasket. Just a thought.
Have one more theory. My new theory is to wait for a lot of forum input before theorizing.
Mr. T. Minnesota
soundguy
01-12-2013 13:23:24
 Re: FEL Sudden drop under load ( update) in reply to Mr. T. Minnesota, 01-12-2013 10:34:49
dry paper oe style gasket.. nothing else.
the only other possible mod I would do is have the cover cut for an oring that then sandwiched down onto the deck.. I have seen a fergy with a deck cut oring boss.. etc.
still.. I've done plenty N with paper gasket and have never had to go back in as long as the deck and cover were clean and smooth there.
remember if you put a metal crush gasket around the port.. the cover will not set true, making the outside of the cover be at a different angle, and thus encourage blow out.
the engineers covered this by 1939.. no need to reinvent it.
HCooke
01-12-2013 11:43:36
I've done a half doz of these. Just the paper gasket and no sealer. Use some 7/16" bolts with the heads cut off to hold the gasket in place while lowering the top cover into place. I also use a small wedge between the main draft spring and the rear end to hold the cover up while I re-position the control arm.
old
01-12-2013 11:39:30
Correct gasket and NO type of gasket crude. Trying to fix what has worked for decades does not work with this area of this type/modal of tractor
TheOldHokie
01-12-2013 10:51:08
I'm thinking that grommet is a good recipe for a cracked top cover. It takes very little unevenness on the clamping surfaces to crack a flat casting like that.
TOH
JMOR
01-12-2013 11:14:02
 Re: FEL Sudden drop under load ( update) in reply to TheOldHokie, 01-12-2013 10:51:08
Quoting Removed, click Modern View to seeThat little "ckick" when you torque down on a cast iron part is a real downer! :cry:
TheOldHokie
01-12-2013 14:10:51
 Re: FEL Sudden drop under load ( update) in reply to JMOR, 01-12-2013 11:14:02
Sounds like you have had some personal experience along thes lines. Hope it was something cheap like a thermostat housing :roll:
TOJ
ASEguy
01-12-2013 14:42:27
 Re: FEL Sudden drop under load ( update) in reply to TheOldHokie, 01-12-2013 14:10:51
I've done that. I also couldn't agree more with the possibility of a cracked cover.
ASEguy
01-12-2013 14:42:27
ASEguy
01-12-2013 14:42:10
JMOR
01-12-2013 10:43:04
Quoting Removed, click Modern View to seeUnless the metal surfaces are damaged, the paper gasket has been the working solution to sealing those parts for over 70 years...no new "invention" needed now.
