Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: FEL Sudden drop under load ( update)
[Return to Forum]
Mr. T. Minnesota
01-12-2013 07:37:57
68.170.114.158
Forum Members,
Thanks for the info of possible solutions on the FEL sudden drop N syndrome. Removed the shifter lever cover and ran the 8N this morning and found fluid gushing all over. First thought it was the piston, but found a large 1/2 by 1/2 inch section of gasket suspended in the mechanism of the top cover. I am going to replace it this morning.
Question is, is there something better than picture framing mat board to use as a gasket? The mat board is quite tough. Any thoughts are welcome.
Mr. T. Minnesota
[Reply]   [No Email]
old
01-12-2013 07:51:23
209.86.226.54
Re: FEL Sudden drop under load ( update) in reply to Mr. T. Minnesota, 01-12-2013 07:37:57
As H-Cooke said get the correct gasket or your going ot be doing it again very soon and it is not fun to do that job. Most any good NH/Ford dealer should have that gasket on hand. Even an O'Reilly's should be able to order you one or this site. I said a dealer first because you can get that today maybe
  [Reply]  [No Email]
HCooke
01-12-2013 07:44:38
99.3.166.100
Because of the high pressure involved, I would use a ready made gasket (avail here at YT and other places). No gasket goop on that gasket either.
  [Reply]  [No Email]
Mr. T. Minnesota
01-12-2013 10:34:49
68.170.114.158
Re: FEL Sudden drop under load ( update) in reply to HCooke, 01-12-2013 07:44:38
HC,
Checked the parts department and found the gasket set. What am I going to do with all that mat board stored in the shop?:):) Thought about inserting a modified copper grommet into the oil port opening of the gasket. Just a thought.
Have one more theory. My new theory is to wait for a lot of forum input before theorizing.
Mr. T. Minnesota
  [Reply]  [No Email]
soundguy
01-12-2013 13:23:24
184.233.184.22
Re: FEL Sudden drop under load ( update) in reply to Mr. T. Minnesota, 01-12-2013 10:34:49
dry paper oe style gasket.. nothing else.
the only other possible mod I would do is have the cover cut for an oring that then sandwiched down onto the deck.. I have seen a fergy with a deck cut oring boss.. etc.
still.. I've done plenty N with paper gasket and have never had to go back in as long as the deck and cover were clean and smooth there.
remember if you put a metal crush gasket around the port.. the cover will not set true, making the outside of the cover be at a different angle, and thus encourage blow out.
the engineers covered this by 1939.. no need to reinvent it.
  [Reply]  [No Email]
HCooke
01-12-2013 11:43:36
99.3.166.100
I've done a half doz of these. Just the paper gasket and no sealer. Use some 7/16" bolts with the heads cut off to hold the gasket in place while lowering the top cover into place. I also use a small wedge between the main draft spring and the rear end to hold the cover up while I re-position the control arm.
  [Reply]  [No Email]
old
01-12-2013 11:39:30
209.86.226.32
Correct gasket and NO type of gasket crude. Trying to fix what has worked for decades does not work with this area of this type/modal of tractor
  [Reply]  [No Email]
TheOldHokie
01-12-2013 10:51:08
108.22.206.63
I'm thinking that grommet is a good recipe for a cracked top cover. It takes very little unevenness on the clamping surfaces to crack a flat casting like that.
TOH
  [Reply]  [No Email]
JMOR
01-12-2013 11:14:02
72.181.173.171
Re: FEL Sudden drop under load ( update) in reply to TheOldHokie, 01-12-2013 10:51:08
Quoting Removed, click Modern View to seeThat little "ckick" when you torque down on a cast iron part is a real downer! :cry:
  [Reply]  [No Email]
TheOldHokie
01-12-2013 14:10:51
108.22.206.63
Re: FEL Sudden drop under load ( update) in reply to JMOR, 01-12-2013 11:14:02
Sounds like you have had some personal experience along thes lines. Hope it was something cheap like a thermostat housing :roll:
TOJ
  [Reply]  [No Email]
ASEguy
01-12-2013 14:42:27
68.186.162.134
Re: FEL Sudden drop under load ( update) in reply to TheOldHokie, 01-12-2013 14:10:51
I've done that. I also couldn't agree more with the possibility of a cracked cover.
  [Reply]  [No Email]
ASEguy
01-12-2013 14:42:27
68.186.162.134
  [Reply]  [No Email]
ASEguy
01-12-2013 14:42:10
68.186.162.134
  [Reply]  [No Email]
JMOR
01-12-2013 10:43:04
72.181.173.171
Quoting Removed, click Modern View to seeUnless the metal surfaces are damaged, the paper gasket has been the working solution to sealing those parts for over 70 years...no new "invention" needed now.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
