TractorLinks.com
Show Parts for Model:
Re: FEL Suddenly dropped under load ??
Mr. T. Minnesota
01-11-2013 19:46:03
SG,
This evening I did a complete running check, removal and reinstall of the pump, but to no avail?? Is there anything on the upper mechanism that could snap? The three point lift arms are not operating either. They used to move some before the FEL arms would move, not now.
Any other thoughts or ideas are appreciated.
Mr. T. Minnesota
old
01-11-2013 19:55:08
 Re: FEL Suddenly dropped under load ?? in reply to Mr. T. Minnesota, 01-11-2013 19:46:03
So you pulled the Hyd pump but not the top cover?? Sounds like maybe the hyd cylinder has a major leak or the top cover gasket may have blown out but that is not common unless the relief valve stuck closed and of that happened that could have much worse things happening and blowing pump gaskets etc.
Mr. T. Minnesota
01-11-2013 20:09:40
 Re: FEL Suddenly dropped under load ?? in reply to old, 01-11-2013 19:55:08
Old,
If the hyd cylinder had blown there would have been a fluid shower when I did a visual operating check before taking things apart. Checked the relief valve when checking the intake and exhaust valves. All valves were in good shape. Still think something snapped in the top cover. Will check that tomorrow. Any other thoughts are welcome.
Mr. T. Minnesota
soundguy
01-12-2013 13:05:47
 Re: FEL Suddenly dropped under load ?? in reply to Mr. T. Minnesota, 01-11-2013 20:09:40
you are missing HUGE diagnostic observation opportunities.
nothing magic happens int he top cover.
if you manyally actuate the control valve, the pump will do it's thing with the top cover setting on your kitchen takle no where near the tractor.
when you move the valve int he pump.. what happens?
old
01-11-2013 21:01:01
Well if something snapped it would be the lift arm cylinder linkage and I can not say 100% sure but if that did happen I would think you would get a mass amount of fluid from the cylinder area but with a set up like that one at best it is a I hope it works. Never have liked trying to tap into the hyd system on the N series fords or for that matter the hundred or ?01 either
