| Ford 9N, 2N & 8N Discussion Forum |
Topic: 6v or 12v coil?
[Return to Forum]
| Author |
[Modern View]
| Dave/MO
01-11-2013 17:40:35
173.186.176.79
I own a 41 9N that has been converted to 12v. What is the difference in amps between a 6v coil and a 12v coil. I am not sure what I have and the only resistor on the tractor is the ballast resistor. Do I need the resistor block or can i run with just the ballst resistor? Any info would be nice. |
[Reply] [No Email] | |
| Charles Krammin
01-12-2013 06:39:51
69.174.184.231
Re: 6v or 12v coil? in reply to Dave/MO, 01-11-2013 17:40:35
| On my 45-2N I run a 12V, positive ground generator, wuth voltage regulator and a 6volt (1.5 ohm) coil, with 2 resistors (!2 to 6 volt, ballast resistor. I like this setup, as the front mount coil is subject to intense heat from the radiator and this keeps it cooler. Ialso get 12volt hotter spark at cold statup. The positive ground also directs the spark to the center electrode of the sparkplugs. Points have also faired well in this setup. On my Ford 600 sidemount, I however run a true 12volt coil, with ballast resistor (don't really need it), with switched wires on coil for changing polarity, as I use a Neg ground polarity alternator, with internal regulator. This setup also has all the good characteristics, as above. The "Tin can sidemount can stand the heat better.Charles KramminSW MI |
| soundguy
01-11-2013 19:11:23
107.41.102.121
| | ditto what bruce said. I personally like a 2.5 ohm coil and oem resistor combo. best of both worlds in a compromise setting. hotter startup sparks that drop primary current in a few minutes after start. |
| old
01-11-2013 17:53:35
209.86.226.32
| I believe what your trying to find out if not how many amps but what the ohm value should be between to 6 and 12 volt coil. I can not help you with that but figured I would make sure of what you are asking so maybe some one else can help you better then I can |
| Dave/MO
01-11-2013 18:14:20
173.186.176.79
Re: 6v or 12v coil? in reply to old, 01-11-2013 17:53:35
| You are absolutely right. I meant to ask what the Ohm differences are. Sorry peoples. |
| Bruce (VA)
01-11-2013 18:25:50
24.125.80.178
Re: 6v or 12v coil? in reply to Dave/MO, 01-11-2013 18:14:20
| | A 12v frontcoil will have an internal resistance of 2.5 ohms or more. A 6v frontcoil will have an internal resistance of .3 to 1.5 ohms. You always need the OEM ballast resistor on a frontmount; 6v or 12v coil doesn't matter. If you have a 6v frontcoil & a 12v conversion, you will need an additional resistor to limit coil current to less than 4 amps. You do not need any additional resistors w/ a 12v coil. See tip # 30 at the link below. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
