TractorLinks.com
Show Parts for Model:
Re: FEL Suddenly dropped under load ??
TheOldHokie
01-11-2013 16:39:38
The N-series three point control valve was never intended to provide the fine grained control needed for controlling a FEL. A dump valve installed in the loader hydrauilc line that was manually activated by lowering the 3pt quadrant was the 40's/50's way of dealing with that twitchy and erratic behavior. Personally I would recommend an inexpensive SA directional control valve with separate return cicuit installed between the test port and loader cylinders. Leave the 3pt control in the full up position (constant ouput at the test port) and use the loader control valve to raise/lower the loader. Cost you about $75.
TOH
