TractorLinks.com
Show Parts for Model:
Re: Ring gear diameter on flywheel
cooter 143
01-10-2013 11:56:56
I believe that is the linear expansion rate, in which case you would need to use the circumference of the flywheel and gear. I think it would workout to require at least a 300deg delta between pieces.
TheOldHokie
01-10-2013 12:25:42
 Re: Ring gear diameter on flywheel in reply to cooter 143, 01-10-2013 11:56:56
cooter 143 said: (quoted from post at 15:56:56 01/10/13) I believe that is the linear expansion rate, in which case you would need to use the circumference of the flywheel and gear. I think it would workout to require at least a 300deg delta between pieces.
It is a linear expansion problem and circumference is a linear function of diameter: c = Pi x d. If you do the algebra I think you will find that the process of computing the linear expansion of the circumference and from that the new diameter reduces to the more direct coefficient of expansion x diameter method I gave. I could be wrong but....
TOH
This post was edited by TheOldHokie at 12:55:05 01/10/13.
