TractorLinks.com
Show Parts for Model:
Re: Need wireing help
Dell (WA)
01-09-2013 20:55:48
Brian........you write......"The solinoid is marked where the battery lead connects one one side. It also shows a white wire going from the switch to the small lead on the solinoid but I can't understand why" ........ONLY the 8N had 3-terminal starter mounted solenoid. The 9N/2N has a roundcan voltage regulator under the battery tray that many neubie shadetree mechanics might mistake for a solenoid. Most likely, the white wire is providing power to the ignition switch and thru the "infamous ballast resistor" to the top terminal of the 4-nipple squarecan ignition coil. .........Dell, a 12-volt advocate for the right reasons, who knows 8-ways to convert to 12-volts and they all work the first time
