Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Need wireing help
[Return to Forum]
Brian Livingstone
01-09-2013 17:17:14
198.254.146.53
Hello all. I am new to this forum as I purchased my first tractor
3 weeks ago. It is a ford 2n . The former owner had converted
to 12 volt with some kind of home brew electronic ignition .
There was 2 different modules screwed to the hood and did it
look awfull. I purchased a new 12 volt conversion kit but my
wireing knowledge is very limited. I have instructions but they
are somewhat unclear to me as how the connections work at
both the starting switch and the starter solinoid. The solinoid is
marked where the battery lead connects one one side. It also
shows a white wire going from the switch to the small lead on
the solinoid but I can't understand why.
I apologize for my ignorance in this area but I sure would
appreciate any advice you could offer.
Thank Brian ( new 2n owner)
[Reply]   [No Email]
JMOR
01-09-2013 21:00:43
72.181.173.171
 Re: Need wireing help in reply to Hobo,NC, 01-09-2013 17:17:14
"The 9N/2N has a roundcan voltage regulator under the battery tray"
Its past you bed time, Dell.
cutout
cutout
cutout
[Reply]  [No Email]
Dell (WA)
01-10-2013 09:39:35
71.217.23.84
 Re: Need wireing help in reply to JMOR, 01-09-2013 21:00:43
yep, past m'bedtime.........cutout Dell
[Reply]  [No Email]
Dell (WA)
01-09-2013 20:55:48
71.217.23.84
 Re: Need wireing help in reply to Brian Livingstone, 01-09-2013 17:17:14
Brian........you write......"The solinoid is marked where the battery lead connects one one side. It also shows a white wire going from the switch to the small lead on the solinoid but I can't understand why" ........ONLY the 8N had 3-terminal starter mounted solenoid. The 9N/2N has a roundcan voltage regulator under the battery tray that many neubie shadetree mechanics might mistake for a solenoid. Most likely, the white wire is providing power to the ignition switch and thru the "infamous ballast resistor" to the top terminal of the 4-nipple squarecan ignition coil. .........Dell, a 12-volt advocate for the right reasons, who knows 8-ways to convert to 12-volts and they all work the first time
[Reply]  [No Email]
HCooke
01-09-2013 18:27:20
70.195.10.140
I am not a 12v expert. Here is a wiring diagram by JMOR. There are several ways to do this. Note the 9/2Ns do not have a solenoid normally but it is possible that the previous owner has bypassed the safety started and added a key automotive type starter and a solenoid. I have one like that presently and will be converting it back to the original starter switch.
[Reply]  [No Email]
Brian Livingstone
01-09-2013 19:19:52
198.254.146.53
 Re: Need wireing help in reply to HCooke, 01-09-2013 18:27:20
So this diagram shows it wired without the starter solinoid. That is interesting because the original solinoid was also bypassed by the previous owner. Is this then the proper way to wire a 2n?
[Reply]  [No Email]
HCooke
01-10-2013 09:40:55
70.195.64.116
 Re: Need wireing help in reply to Brian Livingstone, 01-09-2013 19:19:52
Can you take a picture and show us what you are calling a solenoid? There was no solenoid on these tractors originally, but one could have been added.
[Reply]  [No Email]
old
01-09-2013 20:58:27
209.86.226.32
As JMOR said the 9N and 2N used a starter button that you push down and that in turn pushes a contact-or that then sends battery voltage to the starter and NO true solenoid was on it.
[Reply]  [No Email]
JMOR
01-09-2013 20:27:03
72.181.173.171
Quoting Removed, click Modern View to see9n & 2N had no solenoid. They had the mechanically/hand operated switch. In that regard the diagram is a good one. As it says, it reflects the TISCO conversion kit wiring recommendations. Personally, I do not like the "alternator only ammeter" connection. The Fords used a "net ammeter" connection & I like that connection (below).
[Reply]  [No Email]
Royse
01-09-2013 18:19:27
69.36.49.151
Welcome to the forum Brian.
Are you planning on keeping the "home brew" EI?
If so, it might help if you could post some pictures of it.
Odds are its an EI from one of the regular manufacturers.
The wiring is not that tough, folks here can and will help.
Do you have a one wire or three wire alternator?
JMOR has pictograms for both, and I agree they are spot on.
You can find them by simply Googling "wiring diagrams by JMOR"
Congrats on the new tractor!
[Reply]  [No Email]
old
01-09-2013 18:12:43
209.86.226.19
If I was talking to you on the phone I could explain it in my sleep but on here it takes a good bit to do. I have done many 12 volt conversions on many tractors so if you find you need help my e-mail is always open and I will do my best to help you if you need it and give you my home number there to boot. I have had many people call me over the years and some call me still
[Reply]  [No Email]
Tom Beddard ENC
01-09-2013 17:29:50
173.219.98.53
JMOR will be in soon and has pictograms to follow on your project. I used them on my 462N & they are spot on.
[Reply]  [No Email]
Brian Livingstone
01-11-2013 20:31:20
198.254.146.53
 Re: Need wireing help in reply to Tom Beddard ENC, 01-09-2013 17:29:50
Thanks to all of you for your help . You are a great bunch .
The tractor is so close to starting but just won't keep going . I am wondering if it has something to do with the in line resistor I installed that came with he kit. Am I correct that the additional resistor is not required with a 12 volt coil? I am not positive what coil I received with my conversion kit but I assume it is a 12 volt. Is there an easy way to tell
Thanks again . Brian
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
