Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Oil Pressure
[Show Entire Topic]  [Return to Forum]
TheOldHokie
01-09-2013 15:29:42
74.110.73.65
John Kamerer said: (quoted from post at 18:47:42 01/09/13) I just restored a 46 2N motor. Runs great, BUT after it warms up the oild pressure drops to 1 maybe 2 lbs. Starts out at 35 - 40 lbs. What gives? is the spring tension on the pressure thingy bobby up front weak?
If you have 35-40 PSI at startup the "spring thingy bobby" is producing at least 35-40 PSI of cracking pressure. The "spring thingy bobby" doesn't know or care whether the oil is hot or cold just how much pressure it is holding back. Your problem is elsewhere.
Loss of pressure when the oil gets hot says you have overly wide clearances or a leak somwhere in the oil system. First thought would be to verify the cover plate on the pump is sealed good and tight. Any leak there will kill pump pressure.
TOH
This post was edited by TheOldHokie at 15:33:07 01/09/13.
[Reply]   [No Email]
JohnKamerer
01-09-2013 15:45:04
184.157.248.65
Re: Oil Pressure in reply to TheOldHokie, 01-09-2013 15:29:42
Looks like i need to drop the pan and check the nuts on the oil pump.. I remember tighting these as i wire the nuts. the oil filter line on the bottom goes arround the back of the block and enter the inspection cover for the valve adjusters. inside it sprays out the the valves. I thought this was letting to much oil pass thru. So, I installed a shut off valve in the line and as i close the valve I can get oil pressure up to 10 lbs but then I hear increasing valve noise.
  [Reply]  [No Email]
Bill Rowles
01-10-2013 01:31:07
76.2.232.2
Re: Oil Pressure in reply to JohnKamerer, 01-09-2013 15:45:04
I think I would replace the oil pump with a new or rebuilt one. Also, the suction tube that allows the pump to get oil from the sump reservoir may be allowing air to leak into the oil pump.....commonly the silver solder/braze joint between the suction pipe and oil pump housing fails (gets loose) and allows air into the pump. If the pump drive gear was damaged by poor pump operation or the pump sucking some metal from the sump in the engine's previous history (it was seized!),the pump is suspect.
  [Reply]  [No Email]
JohnKamerer
01-09-2013 16:20:40
184.157.248.65
Yep it's what it does. I've not seen this before either. But, who knows what some users do when they try to fix things. The govenor does not have a oil inlet. Do I need to install one and run the oil line there? The casting on the block shows B116 which I think means a Feb 11, 1946 engine. I got this out of Kamloops BC for $500 and it had almost new tires all around. but the engine was siezed up. I restored an 8N 3 yrs back with all your help on the forum.
  [Reply]  [No Email]
TheOldHokie
01-09-2013 16:29:10
74.110.73.65
Re: Oil Pressure in reply to JohnKamerer, 01-09-2013 16:20:40
JohnKamerer said: (quoted from post at 20:20:40 01/09/13) Yep it's what it does. I've not seen this before either. But, who knows what some users do when they try to fix things. The govenor does not have a oil inlet. Do I need to install one and run the oil line there? The casting on the block shows B116 which I think means a Feb 11, 1946 engine. I got this out of Kamloops BC for $500 and it had almost new tires all around. but the engine was siezed up. I restored an 8N 3 yrs back with all your help on the forum.
A farmerization that probably breaks things and possibly why you had a siezed engine. That oil line flow is inline with the mains/rods and is sucking off pressure. Remove that kludge - the valves do not need it and it only confuses the issue.
TOH
This post was edited by TheOldHokie at 16:30:55 01/09/13.
  [Reply]  [No Email]
JohnKamerer
01-09-2013 16:35:04
184.157.248.65
Re: Oil Pressure in reply to TheOldHokie, 01-09-2013 16:29:10
  [Reply]  [No Email]
TheOldHokie
01-09-2013 16:53:46
74.110.73.65
Re: Oil Pressure in reply to JohnKamerer, 01-09-2013 16:35:04
Sorry - I didn't read carefully and jumped in with foot in mouth. I thought the line was off the tee at the back - not the oil filter outlet. That rerouting won't hurt anything.
  [Reply]  [No Email]
JMOR
01-09-2013 16:45:07
72.181.173.171
Quoting Removed, click Modern View to seeIf I follow your oil line description correctly.........then what has been done is that the oil filter outlet (bottom center) has been routed into the valve cover instead of into the governor (or as before the governor oiling scheme, into the block(see pic), just below the filter. I would want it corrected, too, but I'm afraid this (where oil filter return dumps) will NOT impact your low oil pressure.
  [Reply]  [No Email]
JohnKamerer
01-09-2013 17:37:34
184.157.248.65
Re: Oil Pressure in reply to JMOR, 01-09-2013 16:45:07
Thanks for the pic. I'll run it to the block as shown. But I agree it won't help the oil pressure. or is there a good reason they went to the govenor?
  [Reply]  [No Email]
TheOldHokie
01-09-2013 18:02:26
74.110.73.65
Re: Oil Pressure in reply to JohnKamerer, 01-09-2013 17:37:34
Yes - the early governors were wearing out prematurely due to lack of lubrication.
TOH
  [Reply]  [No Email]
JMOR
01-09-2013 15:50:49
72.181.173.171
JohnKamerer said: (quoted from post at 19:45:04 01/09/13)
" the oil filter line on the bottom goes arround the back of the block and enter the inspection cover for the valve adjusters. inside it sprays out the the valves."...........sorry, but not on an N tractor!
This post was edited by JMOR at 16:16:47 01/09/13.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
