TractorLinks.com
Order Ford 9N Parts Online
Re: replacing lift control valve on 9N
TOM N MS
01-08-2013 03:44:14
Remove the seat-remove both side covers- now with seat removed, you can bear hug the rear diffy housing and reach in both side cover holes--spread the fork and disconnect it from the control valve--slide the control valve out of the pump-slide in new one------spread the fork and reattach it to the control valve "T"...Reattaching the fork to the T is easier said than done but is doable. Install covers..Left side cover can be a little aggravating because it wants to twist and flop around..notice inside where the tab on the PTO lever must go-position it where it lines up then it will drop in place.HTH
