Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Leaning wheel to axel extension (update)
Bill Rowles
01-07-2013 06:47:52
I think all 8N are the same.....but if others disagree, hopefully they will say so here. The 9N/2N will not work. Your used parts source person may have an opinion about interchangeability too, but be carefull because sometimes the person on the phone or behind the counter knows less than you and is willing to guess if he can sell a part......I would take the old one with me on the 50 mile drive to match it up before buying. Be carefull because the left and right are not interchangable so check the top of the new spindle carefully to be sure they give you the correct side.
Paul in MN
01-07-2013 13:18:57
 Re: Leaning wheel to axel extension (update) in reply to Bill Rowles, 01-07-2013 06:47:52
Look carefully at the position of the woodruff keyway compared to the direction of the spindle axle. This is where the left and right side spindles are different.
Even though badly abused, it might be possible to save the hub. You can take out a badly damaged inner bearing race with an arc welder (stick or MIG) by welding a good hot continual bead around the inner circumference of the race. The welding shrinks the race and it comes out easily. An Oxy torch on that same race will probably nick the hub, as you usually can't see through all the rust, muck, and buggered metal.
Both the hub and spindle (and grease seal) can be ordered from this site.
Paul in MN
