Mr. T. Minnesota
Forum members,
When it gets into the 30 degree temperature range in Minnesota, it is time to work on the 8N.
I attempted to remove the hub from the 8N this afternoon and it seems to be hung up on the spindle. Is that the way they come off, with persuasion like with a hammer? I need the SOP on what to expect when removing the hub to replace the bearings. It comes out about 3/4 to 1 inch out and then it stops. Any help is appreciated!
Novice hub puller
Mr. T. Minnesota
Novice hub puller
Mr. T. Minnesota
