Kirk NJ - Meyer Snow Plow
I got to thinking today, and we have an old 6' Meyers snow plow just sitting unused. Its the same width as my 3 pt blade and I remembered you posting pictures of your setup. After looking through the archives this afternoon and evening, I saw your pictures, but am a bit curious as to how you mounted the frame to the rear axle.
Thanks for the advice,
carpetfarmer
I used the angle iron style brackets used for sway bars. The kind found on the hundred series. They sell at TSC. They have a pin with serveral holes and bolt under the axle. Drilled a hole in the angle iron that comes back from the the front frame to fit the bracket pin. You can also tack on a couple pieces of steel,kind of like what the ARPS frame has to keep from racking.
Kirk
