641 6v solenoid wiring
WayneMo
My 641 6v solenoid has 2 small terminals. I assume one connects to the switched side of the ignition switch and the other connects to ground through the starter button. Which one does the top terminal connect to and which does the bottom terminal connect to? Also the bottom terminal now has 2 wires connected to it instead of 1, what is the second wire connect to?
(quoted from post at 00:45:54 01/06/13) My 641 6v solenoid has 2 small terminals. I assume one connects to the switched side of the ignition switch and the other connects to ground through the starter button. Which one does the top terminal connect to and which does the bottom terminal connect to? Also the bottom terminal now has 2 wires connected to it instead of 1, what is the second wire connect to?
ee other forum!
