9n lift cylinder repair
dmiller
Rebuilt the cylinder. Now what's the trick to getting the forks to line up so that the top plate will go back on???? Can't get the top of the housing to go in place, seems to be the forks that connect to the control arm???
Decided to try an old brake spring (seems to be about the same tension and length as the one I'm needing to replace)between the forks and the end of the cylinder.
I just straddle the tractor and put one arm in each inspection port and spread the fork and put it back on. Not easy. Hobo made a special tool for the task, perhaps you can search the archives for it.
(quoted from post at 07:16:04 01/06/13) I just straddle the tractor and put one arm in each inspection port and spread the fork and put it back on. Not easy. Hobo made a special tool for the task, perhaps you can search the archives for it.
http://ytforums.ytmag.com/viewtopic.php?t=823852&highlight=tool
Both my shoulders have been busted up along with to many years wranching,,, I don't have what it takes to he-man them on anymore :(
That looks like a good idea, do you put them back
on with that too?
Stan
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
Thanks to all, found a picture of a 9N cutaway on the internet as well. Now it seems fairly simple (not necessarily easy) to tell where they go and how they have to get there.
