Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 9N Hydraulics not operating, did go up once...
[Return to Forum]
FiremanKyle
01-05-2013 18:30:23
99.33.206.138
Well, I've done some more work on my Dad's tractor (probably might as well consider it mine). The Hydraulics on the initial run went up and wouldn't go down. The Hydraulic/Trans fluid was low, but is sufficient now. This been parked for a few weeks, so the lift arms finally reduced some tension. Today my friend and I each stood on separate lift arms and did a little hammering/tapping on lift shaft arm, the lift arms finally lowered. Now the Hydraulics almost appear to be dead. There is now no action with the lift arms at all (up or down). When Exercising the Touch Control lever when in the lower position it seems to want to spring back. I do not see any issues when looking in the inspection cover (right side) currently.
Tractor sat for at least 10 years with no usage in beautiful Michigan. I'm thinking it might be best to clean the pump and change the oil, since it may have never been changed. So other than those basics, what could be the the most problematic issue that we think this could be, with out going for a total Hydraulic pump repair kit.
Thanks for some insight.
[Reply]   [No Email]
FiremanKyle
01-10-2013 05:03:27
108.68.72.124
 Re: 9N Hydraulics not operating, did go up once... in reply to FiremanKyle, 01-05-2013 18:30:23
I got a Hydraulic repair video that is an oversight, which shows the key points to for removal/repairs. so far I have the three pt lift arms disconnected and the top ring bolts loosened, Just go to find a container big enough to hold that much oil (thinking a tote).
[Reply]  [No Email]
Bill Rowles
01-07-2013 07:27:28
76.2.232.2
If it were mine, I would remove the PTO shaft and pump to clean it out real good. However, if you have never removed the pump on one of these tractors, I recommend getting some help from someone who has done it. It is both messy and tricky to disconnect the control valve from the fork and also takes some skill to reconnect it.
[Reply]  [No Email]
39Ford
01-07-2013 18:24:44
50.129.146.82
 Re: 9N Hydraulics not operating, did go up once... in reply to Bill Rowles, 01-07-2013 07:27:28
Anyone have a photo or some tips on how the pump connects to the linkage? My '39 came with the pump out of the tractor, and I cant seem to figure out how it all goes together.
[Reply]  [No Email]
ZANE
01-06-2013 07:47:07
98.83.71.94
Stuck or disconnected control valve.
Zane
[Reply]  [No Email]
JMOR
01-05-2013 20:38:45
72.181.173.171
Check fork to "T" on valve for connection as shown. The touch control lever trying to spring back up, from the down position is normal, as when you push it down, you are stretching a spring & that spring wants to pull back to its pre-stretched position. That is why the cork friction disk is there.
[Reply]  [No Email]
soundguy
01-05-2013 18:42:14
184.246.122.194
that lever is just mechanical linkage.
time to pop the hyd side cover off and see if the control fork is hooked to the 'T' shaped valve in the pump and actually moving it gfreely in and out like it should.
70 ys of gunk and grit and water tend to make this stick.. especially when they set unused for 10ys at a pop..
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
