TractorLinks.com
Show Parts for Model:
Re: where is the oil coming from?
it me again
01-05-2013 16:37:11
you blew it up.. but don't "worry" take the head off and replace the head gasket.. but when you do it .. replace head bolt too with nut.. no washer clean up piston and surface clean before replace gasket.. replace the cause too . the water pump and flush radiator and you might have replace the radiator too..
8n1951
01-05-2013 16:57:59
 Re: where is the oil coming from? in reply to it me again, 01-05-2013 16:37:11
now that i have cleaned my shorts, took the head off. had only 60 lbs comp on #2 coolent system has oil every where. whats the best clean up?
soundguy
01-05-2013 17:48:59
 Re: where is the oil coming from? in reply to 8n1951, 01-05-2013 16:57:59
dump some vinegar in there.. then ruin it a lil.. drain.. then go in with water.. run it.. drain.. then go back with AF.. a lil oil won't hurt.
it's likely the HG.. but keep an eye on it in case the block has an issue.
