spring name on 9n Ford
dmiller
Put new rings on the lift cylinder of a 9N. The spring that connects from the back of the cylinder to the forks that connect to the control lever got lost (was laid by the rag pile, found the rag pile in the driveway 50 yards away the next morning, boys let the dog out.).
What is the name for this thing so I can find someone who sells them? It had a hook on either end and was maybe 6-8 inches long.
Thanks
Try Jim.UT. Has sells good quality used parts. He can be reached at webbtractorATgmailDOTcom.
(quoted from post at 21:46:42 01/05/13) Parts available on this site.Take a look, even pictures of parts too!
.........but does YT have the spring that he is looking for??? If yes, then why not be more helpful & point him to it? If not, then why the useless freaking post???!!!
Already looked here, ebay, and other sites. No place seems to have it. Probably all do if I knew the correct name for it.
Its actual name from the FO-4 Manual is Fork Retracting Spring. Its in the illustration FO134, "M" on Page 90. Hope that helps!!
