8N timing cover seal
Earl-IL
We picked up a rope type timing cover seal from Ford Tractor dealer and the seals barely come to the top of the groove. Leaks worse than the old grub we took out. Felpro only has seal in the overhaul set. In our old Ford manual the seals are listed upper & lower. What is our option cut a shim and place under the new seal?? Thanks Earl
(quoted from post at 07:11:41 01/05/13) We picked up a rope type timing cover seal from Ford Tractor dealer and the seals barely come to the top of the groove. Leaks worse than the old grub we took out. Felpro only has seal in the overhaul set. In our old Ford manual the seals are listed upper & lower. What is our option cut a shim and place under the new seal?? Thanks Earl
This site sells an upper and a lower! check them out!
Earl........the flathead V-8 guys found a full circle neoprene seal that fits the nose end of both the V-8 and the N-Tractor crankshaft. NAPA seal p/n: 550199 (40x62x11)
Unfortunately, still need the 2-part rope seal (soaked in hot oil first) for the flywheel end. .......Dell
(quoted from post at 14:17:06 01/05/13) Thanks Mr Geiger,
What the diff. in the top & btm. ??
You got me there. Maybe the length. I have used only two sets and don't remember the difference. maybe someone will chime in with the answer.
Earl.......you ask what is the difference between top and bottom rope seals? ......would you believe COLOR??? ........Dell
I didn't install the seal. But after questions the owner had trimmed the ends of the seal and didn't bunch it up and shape it to the groove. Thanks for the replies. Earl
