TractorLinks.com
Show Parts for Model:
Re: 2n with scary noise
BigDanT
01-04-2013 18:18:41
Tractor has new manifold gasket, don't feel or hear a leak. Pulled plugs,all look the same,clean/tan. Only get the noise after the tractor has warmed up, in gear and pulling some snow. I've tried to get it to knock sitting in the shop but can't. Maybe if I jack it up put it 3Hi ??? I'll try that tomorrow too dern cold tonight...Dan
soundguy
01-04-2013 18:32:12
 Re: 2n with scary noise in reply to BigDanT, 01-04-2013 18:18:41
oil pressure ok? drop any at knock?
any possibility you are having a interference issue when hot ? IE.. did you deck the block or shave the head any?
i'd think if it was piston slap.. or rod slop.. it would do it more or less constantly unless cyl powered down..
a low op knock might appear at low rpm/pressure.. but yours it at a point pressure should be higher...
run her with 3 cyls.. leave 4 out and see if she knocks...
BigDanT
01-04-2013 19:16:28
 Re: 2n with scary noise in reply to soundguy, 01-04-2013 18:32:12
Oil pressure good...40 when first started 35 when warm. PO has passed don"t know history but I haven"t been into the engine at all. Will try 3 cylinders this weekend ...let you know. Thanks Dan
soundguy
01-05-2013 12:44:32
 Re: 2n with scary noise in reply to BigDanT, 01-04-2013 19:16:28
post back after observations.
good luck!
