Berghandler
Have successfully split my 8N, (thanks to Zane's help), and have removed clutch cover, pressure plate and clutch disc in order to get at and remove flywheel in an attempt to replace the ring gear which has bad teeth. Before I start and because this is my first rodeo at this type of surgery, what is the easiest way to remove flywheel from end of crank. I have removed the (4) 7/16-20 cap screws that bolt flywheel to end of crank, and now need to know how to get flywheel off. It seems very tight. Once I get flywheel off then how do I remove ring gear from flywheel. I think I might need to heat ring gear to get it to grow and then slip off, but not sure.
Thanks
Thanks
