Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Flywheel disassembly
jackinok
01-03-2013 15:13:24
bump the flywheel as suggested.what i personally do to remove the ring gear is simply cut them with a torch.then i lay the flywheel down . prop the ring gear up on a brick, block,or three or four sockets so its not touching the ground,and slowly heat it with the torch ,going around it to heat it evenly.as it heats it expands.after it gets evenly hot enough it will fall right on the flywheel. then i tap it with a hammer and punch to make sure it is seated.as it cools it will shrink tightly to the flywheel.
