Mr. T. Minnesota
Forum Members,
I have noticed the right front tire on my '47 8N runs very close to the axle extension. The left tire has a spacing of about 3/4 inch. The right side is about 1/4 inch away from the axle extension. Have also noticed the left hub is spaced out about 3/8 of an inch from the spindle assembly. The right hub is just about touching the spindle assembly. Is this a seal, wheel bearing, or worn spindle problem? Is there a minimum spindle diameter that should be present so this does not happen? I could check that. Not sure how to check for worn bearings. The wheel spins on the axle smoothly. Hope this was explained correctly.
Any help is appreciated!
Mr. T. Minnesota
Mr. T. Minnesota
