Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Lubricant for Assembling Rings, and Pistons in New Sleev
01-01-2013 07:11:44
showcrop said: (quoted from post at 11:06:00 01/01/13)
Ken(Ark) said: (quoted from post at 07:57:33 01/01/13)
Farmerhr said:
For the main bearings I used Lubri Plate No 105 Motor Assembly Grease. I plan to use this material on the rod bearings also.
Should I also use this material when assemblig the rings on the pistons, the pistons and for a coating on the cylinder bore rather than coating them with motor oil ?
We have always used Lubriplate on everything except the rings and wrist pins , which we would submerge in a small bucket of motor oil then let the excess drip off for a few minutes .
Bigger concern was wiping the cylinder with a clean white rag and solvent . Fine honing grit will get trapped in the cross hatch where the oil is suppose to be . Wiping with an oily rag will not dislodge the fine particles .The grit will erode the moving parts and shorten the lifespan . Wipe the cylinder with motor oil after cleaning .
Just to emphasize Ken's post, I don't remember where, but in one of my shop manuals or in the instructions that came with a sleeve kit, there was a strong emphasis on washing the cylinders with soapy water after honing because oil will not remove the fine particles.
I'd just add that most shop manuals recommend against using a solvent as it simply embeds the grit and makes it harder to remove. Wash with hot soapy water and rinse well with clean water.
This post was edited by TheOldHokie at 07:22:13 01/01/13.
