Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Lubricant for Assembling Rings, and Pistons in New Sleev
[Show Entire Topic]  [Return to Forum]
showcrop
01-01-2013 07:06:00
75.67.231.80
Just to emphasize Ken's post, I don't remember where, but in one of my shop manuals or in the instructions that came with a sleeve kit, there was a strong emphasis on washing the cylinders with soapy water after honing because oil will not remove the fine particles.
[Reply]   [No Email]
TheOldHokie
01-01-2013 07:11:44
71.176.187.155
showcrop said: (quoted from post at 11:06:00 01/01/13)
Ken(Ark) said: (quoted from post at 07:57:33 01/01/13)
Farmerhr said:
For the main bearings I used Lubri Plate No 105 Motor Assembly Grease. I plan to use this material on the rod bearings also.
Should I also use this material when assemblig the rings on the pistons, the pistons and for a coating on the cylinder bore rather than coating them with motor oil ?
We have always used Lubriplate on everything except the rings and wrist pins , which we would submerge in a small bucket of motor oil then let the excess drip off for a few minutes .
Bigger concern was wiping the cylinder with a clean white rag and solvent . Fine honing grit will get trapped in the cross hatch where the oil is suppose to be . Wiping with an oily rag will not dislodge the fine particles .The grit will erode the moving parts and shorten the lifespan . Wipe the cylinder with motor oil after cleaning .
I'd just add that most shop manuals recommend against using a solvent as it simply embeds the grit and makes it harder to remove. Wash with hot soapy water and rinse well with clean water.
TOH
This post was edited by TheOldHokie at 07:22:13 01/01/13.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
