TractorLinks.com
Order Ford 8N Parts Online
Re: 8N won't start
Royse
12-31-2012 13:03:43
"Do you think the Blue Streak points are worth the extra bucks?"
Definitely.
Quality parts prevent, or at least greatly lesson this type of problem.
They just plain last longer.
If you have battery voltage to and across the points when open it doesn't
sound like the post through the side is grounded, but you can check it by
checking continuity to ground with the key off, points open and wiggle the
post gently. You should not have continuity to ground.
Give the points a good cleaning and see if that helps. If it does, I would get a
good set on your next trip to town for when the cheap ones do this again.
