TractorLinks.com
Order Ford 8N Parts Online
Re: 8N won't start
mrjim
12-31-2012 12:51:29
Thanks Dell, I'll try that. It's just a cheap set of points that came in a tune up kit from my Ford dealer. They don't even carry the points seperate any more. Do you think the Blue Streak points are worth the extra bucks?
old
12-31-2012 17:08:53
 Re: 8N won't start in reply to mrjim, 12-31-2012 12:51:29
Very simple way to check point if your careful and or do not mind a shock if your not careful. Pop the distributor cap off rotor dust cover. Then turn on the ignition. Make sure the points are closed. Now open and close them by hand. You should both hear and see a spark when you do and you can also hold the coil wire close to the block and watch for spark. Doing that will tell you if your problem is corroded points or something else. By the way if your not careful you may jump but it will not hurt you any more then an electric fence will
