TractorLinks.com
Show Parts for Model:
Re: OT: 1971 Briggs and Stratton Ignition
McBride
12-31-2012 12:06:55
I have use many of them with no problems.
That gap sounds too big.
I think mine came with a piece of paper to set the gap.
Same flywheel is used for either. You don't have to to anything with the magnets.
Put a piece of printer paper between the new unit and the flywheel and tighten it down and then remove paper and give it a try. Make sure the wire coming from it is not grounded.
This post was edited by McBride at 12:19:54 12/31/12.
Jason S.
01-01-2013 09:11:41
 Re: OT: 1971 Briggs and Stratton Ignition in reply to McBride, 12-31-2012 12:06:55
Per the Briggs shop manual the air gap is .010 to .014. It also states that the flywheel but turn at 350 rpm"s minimum to get the magnetron to fire. I worked in small engine for around 10 years and once I did come across a briggs and stratton flywheel that had a weak magnet. Only one time did I ever have that happen. It had very little spark and nothing would change it. I swapped flywheels and changed nothing else and it had the good purple spark.
