Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 8n quit-still no spark
12-31-2012 09:20:11
I put a test lamp between the coil terminal and ground. Cranking dimmed the lamp but it didn"t make it flash. Does this mean a new coil? Thanks for the help in working through this problem.
12-31-2012 09:35:20
 Re: 8n quit-still no spark in reply to davidiowa, 12-31-2012 09:20:11
Quoting Removed, click Modern View to seeIt should be flashing dim/bright/dim/bright in unison with each cylinders firing time. Never completely dark.
If just dimming due to starter load lowering battery voltage, then either coil spring-like pig tail not making good connection to concave screw in distributor or pig tale shorted to distributor body or EI not switching. Check coil seating & connection, then do EI test that I described/pictured.
