Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Hydraulic lift piston
Cameron Duncan
12-31-2012 08:44:18
Fighting a hydraulic problem replacing as I go. Changed the pump, cleaned out sludge and old fluid, now on hydraulic lift piston. I bought a new piston with a single o-ring and leather backing ring to replace the original 3-iron ring piston. Any suggestion on getting the leather ring into it's position? Thought about soaking in very hot water to loosten it to slide on.
FiremanKyle
01-05-2013 18:04:16
 Re: Hydraulic lift piston in reply to Cameron Duncan, 12-31-2012 08:44:18
Seen this link on O-Ring vs Steel Rings...
L. B,
12-31-2012 14:01:04
The leather is per manuf,as it should be a wiper. No?
TheOldHokie
12-31-2012 14:41:53
 Re: Hydraulic lift piston in reply to L. B,, 12-31-2012 14:01:04
No - it is not a wiper. It is a backup ring that supports the backside of the o-ring to help prevent extrusion under pressure. The hard rubber or PTFE versions probably work better.
TOH
L. B.
12-31-2012 19:17:57
 Re: Hydraulic lift piston in reply to TheOldHokie, 12-31-2012 14:41:53
Okee-doe-kee OldHokie
old
12-31-2012 09:46:39
There are 2 types of back up rings. One is made of leather and the other rubber I prefer the rubber ones. Easier to put on and been told they hold up a lot longer
Cameron Duncan
12-31-2012 12:36:23
 Re: Hydraulic lift piston in reply to old, 12-31-2012 09:46:39
Thanks but I already have the leather as per man. rec. so I'll have to try to use it or wait 2 more weeks for a replacement.
soundguy
12-31-2012 16:58:01
 Re: Hydraulic lift piston in reply to Cameron Duncan, 12-31-2012 12:36:23
soak it in hot water. ( real hot ) for 5 minutes.. then lube with some oil.. and then use 2 spoons ( eatin' spoons ) and walk it on like you were beading a tire on a rim..
leather are mostly what I've used. they worked for 50-60 years.. can't be that bad... I HAVE used the rubber ones. they DO go on easier, and have a cup side.. i won't be alive in 50-60 ys to see if they hold up the same as the leather ones.. so don't matter to me.. :)
old
12-31-2012 16:18:35
Wait 2 weeks. What don't you have any tractor dealers close to you??. Shoot the last time I got the NAA piston and all I called the dealer and they had them on hand. I could have had it sent for an extra $10 or drive 40 miles one way so I ordered it and had it in 2 days
mbramble
12-31-2012 13:56:59
If you end up needing the rubber one, send me your address via e-mail and I will send you one.
Mike
mike@bramblett.com
NOXJohn
12-31-2012 09:42:43
I always soak in warm/hot oil not water. The warm oil makes the leather expand and help lube it when sliding on.
Cameron Duncan
12-31-2012 12:37:33
 Re: Hydraulic lift piston in reply to NOXJohn, 12-31-2012 09:42:43
Thanks, that makes sense, I'll try that.
HCooke
12-31-2012 09:15:50
"Thought about soaking in very hot water to loosten it to slide on."
Yep. Oring goes toward the oil. Leather backup ring goes on the side away from the oil.
