| Ford 9N, 2N & 8N Discussion Forum |
Topic: OT: 1971 Briggs and Stratton Ignition
[Return to Forum]
| Author |
[Modern View]
| Hec in Omaha
12-31-2012 08:01:58
184.185.82.51
Howdy all! I hope everyone has had a great Christmas! I am working on a 1971 Montgomery Wards Snowblower. It was made by Gilson Brothers and branded Mongomery Ward. It has an 8 HP horizontal shaft engine on it. This thing is a TANK! It had no spark when I got it So I went to the mower shop and the guy sells me a coil with a built in Magnatron. This coil was supposed to replace the old coil, points and condenser. "Just bolt it on and set the flywheel gap to .10" (Business Card Thickness) and connect the grounding wire to kill switch and your off!", the salesman says. Right? Wrong! After the installation the coil would produce a very weak spark. When I say weak I mean the spark is not visable at all but I get the shock sensation in my hand. So I took the coil back to the mower shop and he gave me a couple of used ones to try incase the new one was bad. Same results. Then I installed new points and condenser and she fired on the 2nd pull. My question is this, Why didn't the coil of a more modern 8 HP motor work on mine? Is there a difference in the flywheels? I figured somebody on this forum has the answer. Thanks in advance! And have a Happy New Year! |
[Reply] [No Email] | |
| JMOR
12-31-2012 08:38:26
72.181.173.171
Re: OT: 1971 Briggs and Stratton Ignition in reply to Hec in Omaha, 12-31-2012 08:01:58
| Quoting Removed, click Modern View to seeYour 0.10 inch is likely a typo, but if really set that wide, that is probably why it wouldn't work. |
| teddy52food
12-31-2012 08:32:17
184.94.175.179
| Magnets are different in the flywheel. They have to be matched up to work. |
| Hec in Omaha
12-31-2012 08:36:03
184.185.82.51
Re: OT: 1971 Briggs and Stratton Ignition in reply to teddy52food, 12-31-2012 08:32:17
| | teddy52food, Thanks for the response. I have found some posts that say you have to repolarize the flywheel magnet to make it work. Hec |
| old
12-31-2012 09:43:31
209.86.226.32
Re: OT: 1971 Briggs and Stratton Ignition in reply to Hec in Omaha, 12-31-2012 08:36:03
| To re-polarize a magnet would be like turning it upside down. I have in fact taken the newer type mag with the built in electronic ignitions and used them many times. The gap you where given sounds way to much to me. When I set them I use a piece of plastic from one of then hard to open pack you get parts etc in to set the air gap. Our I buy one of those add on chips for around $15 that you simple put in place of the points. I have an old Murry lawn tractor that the deck has long since fell off of that I used one of those chips and and it ran the last time I tried to start it. It is dated 1967 by the way |
| Jubilee85(VA)
12-31-2012 09:14:16
24.149.67.138
| | not sure I understand "repolarize the flywheel magnet " It is a permanent magnet? all the B&S flywheels of that era are/were magnets placed in the flywheel - so you aint gonna fix that ! I too think .10 is a weee bit big!!! When I set the coil, I would take a dollar bill and fold it once and slide it in,rotate and put bill back in pocket! I suggest you do that too. |
| McBride
12-31-2012 12:06:55
74.70.171.169
Re: OT: 1971 Briggs and Stratton Ignition in reply to Jubilee85(VA), 12-31-2012 09:14:16
| I have use many of them with no problems.
That gap sounds too big.
I think mine came with a piece of paper to set the gap.
Same flywheel is used for either. You don't have to to anything with the magnets.
Put a piece of printer paper between the new unit and the flywheel and tighten it down and then remove paper and give it a try. Make sure the wire coming from it is not grounded.
This post was edited by McBride at 12:19:54 12/31/12. |
| Jason S.
01-01-2013 09:11:41
174.228.72.166
Re: OT: 1971 Briggs and Stratton Ignition in reply to McBride, 12-31-2012 12:06:55
| Per the Briggs shop manual the air gap is .010 to .014. It also states that the flywheel but turn at 350 rpm"s minimum to get the magnetron to fire. I worked in small engine for around 10 years and once I did come across a briggs and stratton flywheel that had a weak magnet. Only one time did I ever have that happen. It had very little spark and nothing would change it. I swapped flywheels and changed nothing else and it had the good purple spark. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
