Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: SO; What is the B.H.P of an 8N?
[Return to Forum]
Fuddy Duddy
12-31-2012 07:19:46
75.245.4.85
You ask someone what the horse power is of an 8N tractor. You
get a reply like 'At what point are you talking about?'
Here what I copied from another page:
Drawbar (claimed): 23.16 hp [17.3 kW]
PTO (claimed): 27.32 hp [20.4 kW]
Drawbar (tested): 21.95 hp [16.4 kW]
PTO (tested): 23.24 hp [17.3 kW]
Belt (tested): 25.77 hp
When I go buy a lawn mower I can buy the cheaper 3hp or pay a
little more and buy the 5hp.
No questing like will if you want self propelled it has less horse
power even thought there the same motor. I got my new
Hercules motor in Friday. It says on the tag it's Horse Power is
B.H.P. 29.6
Did a little research and found,
1) "Brake horsepower (bhp) is the measure of an engine's
horsepower before the loss in power caused by the gearbox,
alternator, differential, water pump, and other auxiliary
components such as power steering pump, muffled exhaust
system, etc.
2) One boiler horsepower unit, or (BHP), is equal to a boiler
thermal output of 33,475 Btu/h (9.811 kW), which is the energy
rate needed to evaporate 34.5 lb (15.65 kg) of water at 212 °F
(100 °C) in one hour. The unit is not current outside of North
America.
Seems it make a difference if the letters are Capital or lower
case.
Mine are Capital.
So what would the B.H.P. and /or the b.h.p. of an 8N be?
[Reply]   [No Email]
old
12-31-2012 09:35:09
209.86.226.32
 Re: SO; What is the B.H.P of an 8N? in reply to Fuddy Duddy, 12-31-2012 07:19:46
That engine appears to be a military unit am I right??? If so I hope for your sake it is a common one not one that is a mil spec unit because if mil spec parts can be harder to find then hens teeth.
Been decades since I have heard of a person talk about Brake Horse power. Back when I go my first drivers license the state I lived in had a law that let some one at 14 get a motorcycle license if the motorcycle was 5BHP or less and at the time Honda had 3 or 4 and the one I had was a 1967 Honda 50 wish I still had it and a few others I had at one time like a Triumph Tiger 200 1959 model
[Reply]  [No Email]
Dean
12-31-2012 08:10:44
67.172.15.77
The most trusted source of farm tractor performance data is the NE tractor tests.
The Ford 8N was tested three times at the NE tests (4 if you include the 8NAN, which I will ignore), tests Number 385, 09/08/47 - 09/19/47; 393, 05/11/48 - 05-18-48; and 443, 06/16/50 - 16/27/50. Maximum belt/PTO HP figures were 21.06, 22.57 and 25.49, respectively while drawbar HP figures were 13.62, 17.43, and 17.65.
Note: According to the NE data, the 8N was rated at 1750 RPM for drawbar use and 2000 RPM on the belt at the time. Performance date was taken at rated RPM.
Dean
[Reply]  [No Email]
JMOR
12-31-2012 07:53:50
72.181.173.171
[Reply]  [No Email]
Fuddy Duddy
12-31-2012 07:26:39
75.245.4.85
No one on the Oliver page could tell my for sure. What are those two port in the bottom of the oil pan?
Best guess was that it for an independent water line to run heat to the cab.
Any body know for sure what it is?
[Reply]  [No Email]
old
12-31-2012 09:37:49
209.86.226.32
 Re: SO; What is the B.H.P of an 8N? in reply to Fuddy Duddy, 12-31-2012 07:26:39
If that is in fact a Military type engine those could be to run water into and out of to warm the engine up for easy starting. Made it easy to hook up a couple hoses heat water over a fire and then pour the water in and back out on the ground
[Reply]  [No Email]
Fuddy Duddy
12-31-2012 10:11:54
75.245.4.85
 Re: SO; What is the B.H.P of an 8N? in reply to old, 12-31-2012 09:37:49
That's a new theory. You might be right I don't believe it's an oil cooler. Don't seem it would work very good to the heat a cab.
Still want to find someone that knows for sure.
[Reply]  [No Email]
old
12-31-2012 10:23:53
209.86.226.32
 Re: SO; What is the B.H.P of an 8N? in reply to Fuddy Duddy, 12-31-2012 10:11:54
Also could be an easy way to use a couple rods to have 4 guys lift the engine in and out of a machine. So is that an old Military engine??? If YES then that does add some off the wall reason for those wholes since the Military has and does many odd off the wall things that some times make little or no sense LOL
[Reply]  [No Email]
Fuddy Duddy
12-31-2012 17:31:31
75.229.73.169
 Re: SO; What is the B.H.P of an 8N? in reply to old, 12-31-2012 10:23:53
Yes, it's a Military engine. The block looks to be the same as my old engine. I'll need to use my old Bell Housing since the starter is to low on this one. So I'll have to move the oil canister or use the one off my old engine which is the screw on type filter. All the same ports are there as on my old engine. Has a lifting eye on the head for lifting it. I can use any thing that was on my old engine on this block from what I can tell. So I don't see where I would run into problems. You are the second one to say they will be internally different. The other guy didn't reply when asked how. What would the be? Crank turned to different dementions, Rods heaver duty. Different cam? or what. I can't see how this engine will be any different than the one that was in it other than a little larger bore size.
[Reply]  [No Email]
JMOR
12-31-2012 19:16:14
72.181.173.171
 Re: SO; What is the B.H.P of an 8N? in reply to Fuddy Duddy, 12-31-2012 17:31:31
Immediately obvious are spark plugs & plug wires.
[Reply]  [No Email]
old
12-31-2012 17:36:24
209.86.226.27
Could be little or nothing different to it or could be a lot of stuff. When you deal with something that was Military you run into what is called Mil spec and if that is so which it may or may not be depending on the age of the engine. Mil spec stuff causes some very odd and off the wall things that have to meet specs made just for the military and believe me even hammers can have to meet mil spec and believe it or not toilet seats
[Reply]  [No Email]
Dean
12-31-2012 07:54:25
67.172.15.77
Rudimentary oil cooler.
Dean
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
