Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Reg again - what's this about?
[Return to Forum]
Notjustair
12-30-2012 20:14:55
174.229.72.196
I was going try everything I could to get that regulator working without a trip to town in the morning. I can rebuild engines with my eyes closed, but the inside of a regulator mystifies me. It is the only thing I can think of that makes me feel like I have no idea whether my tinkering has improved the situation at all. I would rather spend my day packing wheel bearings.
I took the busted one off and took the cover off. I had two others that had died as well they all looked the same inside. I was hoping for massive scorch marks or the smell of burned lumber. Something to make me feel validated. They all looked pristine inside.
I used sand paper to clean between the points and put it back on. It charges now, but full tilt. At idle it charges 5 amps, but at WOT it runs over 30 amps. So I guess I am still going to get a regulator.
Is there a test I can do on the bench (like with a multimeter across terminals) to validate whether a reg is working correctly without mounting it up? Measure resistance? Anything to not have to put a bad one back on just to feel the sting of dissappointment. Granted, I can do it with my eyes closed now, but it still isn't fun.
[Reply]   [No Email]
TL (va)
12-31-2012 08:06:02
66.59.125.238
 Re: Reg again - what's this about? in reply to Notjustair, 12-30-2012 20:14:55
"Oreilly Auto Parts carries BWD electrical components which are made in the USA. The part number for your tractor is R190.
These also carry a lifetime warranty - Last one I bought was around $65.00"
From a post from DollarBill a while back. Mine is almost a year old now and works great.
Thanks DB!
[Reply]  [No Email]
NOXJohn
12-31-2012 05:46:10
184.5.164.213
Finding a good new 6 volt regulator for an N tractor has been a problem for a number of years. The last time I purchased one was about 10 years ago. Even then I had to buy 3 before one worked properly. Most places will not take electrical parts back even if the don't work correctly out of the box so I had 2 paper weights. I have worked on what looked like perfectly good but not working regulators for hours and have never been able to fix any of them. That is one of the reasons I converted my three 8Ns to 12 volts. The 12 volt alternator is cheap and easy to find and has a lot of operating advantages. If it is 6 volts and working fine I would leave it alone but if it has regulator problems I would convert it before wasting money trying to find a good regulator.
[Reply]  [No Email]
Mr. T. Minnesota
12-31-2012 00:01:36
68.170.114.158
NJA,
I have a shop in my area that works specifically with alternators, generators and the like. Will see what they have to say. I'll get back later this week.
Mr. T. Minnesota
[Reply]  [No Email]
R Geiger
12-30-2012 21:44:58
50.39.151.117
 Re: Reg again - what's this about? in reply to jboyer1028, 12-30-2012 20:14:55
DEN my email should be on , would you send me a cople of the regualtor info also
Thanks
[Reply]  [No Email]
Den N Ms
12-30-2012 22:22:06
184.41.137.166
 Re: Reg again - what's this about? in reply to R Geiger, 12-30-2012 21:44:58
R Geiger,Email sent
[Reply]  [No Email]
Den N Ms
12-30-2012 20:44:26
184.41.137.166
Notjustair,Open your email and I will send you a PDF with some very good info on regulators.
[Reply]  [No Email]
russb wa
12-30-2012 20:27:02
67.185.6.72
NJA, I was thinking along the same lines. What jumps out to me would be spring pressure against magnetic strength. That is to say the thing is a bunch of relay's that are supposed to trigger at the power increase/decrease. So, spring tension comes to mind. fwiw
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
