Reserve gas on the Ns
dan shu
Not to be smart but wanted some clarification. The Ns have a reserve amount of gas if you only open the gas shut off valve "2 turns" or so. Is that two 180* turns or 360* ? Thanks.
Mine opens 7 full turns.
I basically open mine for reserve all the way and back off a quarter turn or so.
My guess is that the last two full turns gets you in the reserve portion of the valve.
Greg
(quoted from post at 22:06:19 12/30/12) Not to be smart but wanted some clarification. The Ns have a reserve amount of gas if you only open the gas shut off valve "2 turns" or so. Is that two 180* turns or 360* ? Thanks.
A turn" is 360 degrees!!! :roll:
Open two turns, after that you are on your way to reserve. I have been using N sediment bowls on my IH tractors for years.(I get tired of walking)
dont forget the shut off valve has to be fully working for that feature to work, if there's a bad or dirty screen ect you'll be out of gas and still see gas in the tank, guess how i know
