| Ford 9N, 2N & 8N Discussion Forum |
Topic: Ooooo, this makes me mad!
[Return to Forum]
| Author |
[Modern View]
| Notjustair
12-30-2012 16:35:56
174.229.72.196
Voltage regulators!!My 8N is the only thing that is 6 volt left on the farm. It is kind of a point of pride that it still starts just fine and works just fine. All except for these cheapo voltage regulators! We are suppose to get measurable snow starting at 6 in the morning. I had the 8N out today moving some rock. All was well. That is, of course, until I started it to put it back in the shed. Waited for the ammeter to swing over after it started. Nothing. The regulator that is in there is about a year old. Finding one that lasted longer than 10 minutes at the time nearly made me bonkers. That whole mess is the reason I get a little sick to my stomach every time I see an ammeter. In all honesty I think it took three regulators to get it to work reliably back then. There is always some reason why I don't convert it. When I had the gen rebuilt last year it was because the 6 volt battery was nearly new. Now I will spend 30 bucks on a regulator because I paid $100 to get the generator rebuilt a year ago. There is always some reason it my tight brain. So I will head to town tomorrow in the snow to get a new regulator and hope this one courtesy of China lasts more than 10 minutes. If I see an 8n sitting by the road I might just buy the whole tractor if it has an original regulator on it. You know, when we built things here and meant them to last. Rant over. |
| TOM N MS
01-01-2013 08:12:59
98.95.135.43
Re: Ooooo, this makes me mad! in reply to Notjustair, 12-30-2012 16:35:56
| If it was mine, it would stay 6 volts... |
| Tim PloughNman Daley
12-31-2012 06:44:33
24.180.180.50
| NJA - Here's a link to a web site about his 9N by Tyler Neff. Scroll to bottom and find the link to the other Ford Tractor web site with wiring diagrams...look under How-To's/ElectricalTim |
12-31-2012 05:05:44
24.180.180.50
| | I admire your dedication to remain 6V/+ GRD as it was in the beginning. I am thinking your VR is fine and that you possibly have a bum wiring issue. Usually new VRs require no adjusting out of the box. If you go to the other Ford Tractor web site, they have most all wiring configs in downloadable pdfs. If you do not know about teh web site -email me for the link. They won't let me post it here. Anyway, did you polarize the generator after installing all those new parts? Whenever you disconnect the battery and then hook it back up, polarize the generator. Also, most reputable starter/alternator shops will bech test all your components FREE. You can take your battery, generator, coil, ammeter, and VR to them and they will test and if all is good tweak everything just right. That means the VR if needed, and the third brush if your genny has one. Then don't muck with the settings. To reinstall, mount all components, but leave battery connections last. Get the wiring connected, then double and triple check it for correctness. Like I said, it sounds like your wiring is incorrect. I'm not critricizing nor questionng your abilities, it's just a possibilty and we all make mistakes, no matter how many times we have done a job. email me... Tim Daley(MI) |
| tractorfix
12-30-2012 18:53:00
69.196.164.225
| Go on ebay and buy the kit to make a 6Volt POS Ground 10SI alternator. |
| JMOR
12-30-2012 18:57:16
72.181.173.171
Re: Ooooo, this makes me mad! in reply to tractorfix, 12-30-2012 18:53:00
| Quoting Removed, click Modern View to seeNo half way stuff for me.....if going non-original, I'll go all the way to 12v neg ground! |
| JMOR
12-30-2012 18:41:10
72.181.173.171
| Quoting Removed, click Modern View to seeIt is amazing isn't it? I still have the original Autolite & it still works!!! |
| russb wa
12-30-2012 20:20:27
67.185.6.72
Re: Ooooo, this makes me mad! in reply to JMOR, 12-30-2012 18:41:10
| I have various and sundry stuff from the land of almost right. I have noticed, on some things, that there are one or two really weird things done almost to sabotage the product. I have a welder and one of the capacitors was connected to ground by the screw that holds one of the rubber feet. Really weird. Similar on some cast iron shop equiptment, basic good design and some weird part that is just barely functional, just fix that and things are ok, sometimes. Its hard to know if there are any obvious things that can be easily fixed in the poster's regulator. fwiw |
| teddy52food
12-30-2012 18:36:57
184.94.175.179
| It may help to add a ground wire from the reg. to the gen. |
| Den N Ms
12-30-2012 16:57:04
184.41.137.166
| Notjustair,You might check with the shop that rebuilt your generator and see if they have a regulator.It may be a better quality one. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
