Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Starter ring gear problems
[Show Entire Topic]  [Return to Forum]
L. B,
12-30-2012 11:32:07
64.187.79.169
UD how does that tacking not unbalance the fw and then what do ya do if ya break teeth off the rg and ya have to remove the tacked in ring? I would think when you would have to grind into the fw that would be a no no. Just asken, not saying it wont work.
[Reply]   [No Email]
Ultradog MN
12-30-2012 13:29:43
184.100.109.75
Re: Starter ring gear problems in reply to L. B,, 12-30-2012 11:32:07
Part One)
I'm guessing that the weight of a 1/2" long tack is about a penny weight = 2.3 grams.
I'm also just guessing that the weight of an N flywheel is about 50 lbs.
50 lbs X 16 ounces to the pound X 28.3 grams to the ounce = 22,640 grams.
One tack is about 2.3 ÷ 22,640 = .01%
I seriously doubt that when the flywheels were new they were within .01% in balance.
Secondly, I suggested four tacks around the circumference of the flywheel. Lets try to make them reasonably equidistant and let's say any decent welder can make each tack within 10% the same size and weight.
So now we are looking at 10% of .01% out of balance. If my arithmetic is right that is about .001% out of balance.
Do you really think that matters??
Do you think even Formula 1 race cars are so exact?
I don't.
Part Two)
Ever heard of a slitting wheel for a 4" angle grinder? They are about 1/16" thick and will cut through ferrous metal like a hot knife through butter
What is to prevent any decent welder from cutting those welds back off should the tractor need to be split for something else? And at that time installing a new ring gear (or new/used flywheel)?
Part Three)
If the ring gear has damaged teeth then the Only way it can be repaired is to split the tractor and install a new one.
If the ring gear is good but only slipping then a reliable and inexpensive way to repair it is to weld it.
Part Four)
See photo below.
About 6 years ago I bought a decent little 8N for $900 because the ring gear was bad. The guy I bought it from had paid a guy about $500 to split the tractor and put a new clutch in it because the ring gear was slipping.
The new ring gear also slipped so he threw in the towel and sold it.
I assumed the flywheel was bad - if two ring gears were slipping.
So I had my neighbor carefully hold the ground on the bolt on the front of the crankshaft and welded the ring gear to the flywheel through the starter hole in 4 approximately equidistant places.
The whole process - R&R the starter and welding took less than an hour.
Then I bolted the hood on properly and installed a used grill I had.
I put $25 worth of gas in it and bought my neighbor a case of beer.
Then I sold the tractor to a guy I know for $1500. A tidy profit.
I know that tractor is still running today because I see it/him when I go up to my land.
I am entirely confident my repair will last as long as the new clutch will.
Part Six)
You may fix your tractor as you see fit. I will fix tractors as I see fit and not fritter away my time on things that do not need it.
Jerry
  [Reply]  [No Email]
TheOldHokie
12-30-2012 16:14:47
108.22.200.173
Re: Starter ring gear problems in reply to Ultradog MN, 12-30-2012 13:29:43
Ultradog MN said: (quoted from post at 17:29:43 12/30/12) Part One)
One tack is about 2.3 <font size="4.5" color="black">÷</font> 22,640 = .01%
I don't.
Part Two)
Part Three)
Part Four)
See photo below.
Part Six)
Jerry
While I don't disagree with you the math/physics doesn't work that way. A typical automotive flywheel static imbalance specification would be roughly .5 ounce-inch maximum. That value represents the static torque caused by an uneven weight distribution across the crankshaft centerline which gets further magnified by dynamic forces when spinning at 2000 RPM.
Coincidentally (??) that imbalance on a 12" diameter flywheel works out to be .5/6=.08 ounce (2.3 grams) at the circumference. So it would be wise to keep the tacks very much the same size and evenly distributed.
TOH
This post was edited by TheOldHokie at 16:48:07 12/30/12 3 times.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
