TractorLinks.com
Order Ford 9N Parts Online
Re: 9N Hydraulic Adjustment
JMOR
12-29-2012 11:14:17
These two statements are not in agreement with one another: The touch control was adjusted" and " I have not been able to move the quadrant ".
i.e, how else is there to adjust the touch control other than moving the quadrant??
Where is spacer that you added?
I expect that either quadrant needs to be moved forward, the valve is sticking in its bore, the spring from the fork to lift cylinder end is weak, or spring (maybe even fork) not connected to valve. Can you reach in through the side inspection port and move the control valve/fork rearward enough to cause lowering?
