Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Downhill engine stumble
Bruce (VA)
12-28-2012 16:41:54
The float is probably hitting the side of the bowl. That & needing the choke out to run says it is carb rebuild time.
Dean
12-29-2012 08:21:12
 Re: Downhill engine stumble in reply to Bruce (VA), 12-28-2012 16:41:54
Bingo.
Check float setting AND the nearly always ignored float drop setting.
Dean
Danman
12-28-2012 16:52:51
Carb was taken apart ,cleaned with carb cleaner and air....
Float is fine and no leaks
old
12-28-2012 19:14:00
 Re: Downhill engine stumble in reply to Danman, 12-28-2012 16:52:51
Well if it only runs choked you have either poor spark which can cause that and you need a blue/white spark that jump a 1/4 inch or more or you missed something in the carb or the float is set wrong. Many carbs get cleaned but not done as well as they need to be and that causes problems like your having or a simple weak spark problem since more gas is burns easier by the weak spark
