TractorLinks.com
Show Parts for Model:
Re: dearborn front plow
jubileepa
12-28-2012 16:25:26
hi new to this forum, awsome picture, I bought a dearborn snw plow this summer. I have a 1954 nna and of course those back brakets were no where in sight, thankfully I knew enough to spot the front ones though. so any help to make or find plans for them would be great thanks. :D
wrenchtech
12-29-2012 14:53:18
 Re: dearborn front plow in reply to jubileepa, 12-28-2012 16:25:26
J, here is a quick drawing of the left rear mount with dimensions. hope this helps.
doug
8N'r--WI
12-28-2012 18:50:49
If you know where to find the "other site" , they have a complete manual for the Dearborn Dozer/Snow Blade that you can copy.
On the same site, in the "How To's" Section, someone has posted closeup pics and diagrams with dimensions for making your own rear brackets for the Dearborn.
There are some real handy guys on both sites that may be able to fab some of the brackets for you. If you start a new post on both sites, just ask if someone would be able/willing to build them, or try it yourself.
I had a complete all original Dearborn Snow Plow that I just sold this summer after upgrading my 860 to do snow plowing. Over the years, I acquired some NOS pieces for it, cables, pulleys, etc. Hard to find as a lot of times the brackets end up being sold with the tractor instead of being taken off with the implement.
Note: Although there were some original frames built for the Jube and 100 Series Tractors, most of the frames were built for the N Series Tractors.....the Jubes and 100 Series are about 4" longer than the N's, so if your plow is too "short", you can just cut the frame, slip in another shorter piece of pipe and weld up so it works on your Jube.
Good Luck.....those plows can move a lot of snow with the right weight systems.
Tim
jubileepa
12-29-2012 14:13:04
 Re: dearborn front plow in reply to 8N'r--WI, 12-28-2012 18:50:49
tim I think your right about the lenth but maybe we can make up the extra lenth in the brakets i need to fab thanks for pointing that out to me. jubileepa
wrenchtech
12-28-2012 18:42:47
I've got my set in the garage. I'll get one out and see if I can make some drawings for you.
doug
Mr. T. Minnesota
12-28-2012 16:58:54
J,
What exactly are you looking for? In my post on this subject I utilized part of the front end plow on an R2 Cat in northern Minnesota. I may have the back assembly (part that hooks to the hydraulic arms). I am not going to use it except for scrap steel.
Mr. T. Minnesota
jubileepa
12-29-2012 14:08:48
 Re: dearborn front plow in reply to Mr. T. Minnesota, 12-28-2012 16:58:54
Quoting Removed, click Modern View to see Thanks for the replys the parts i need are numbers 20,21,29, in the plow manual photo thanks mr T
wrenchtech
12-28-2012 18:35:42
I need one of the pulleys/sheaves that are mounted on the frame towards the front.Do you have one on the remaining part of the frame?
8Nr--WI
12-28-2012 19:02:20
 Re: dearborn front plow in reply to wrenchtech, 12-28-2012 18:35:42
Doug,
Where are you located? If you pick it up, you can have it. Otherwise $15 including the shipping (probably costs $10 for USPS?)
My stompin grounds are from Milwaukee to LaCrosse WI
Tim
Ultradog MN
12-29-2012 05:55:12
 Re: dearborn front plow in reply to 8Nr--WI, 12-28-2012 19:02:20
Hey Tim,
You should have made him promise to say a few Rosaries too so you finally get a buck.
wrenchtech
12-28-2012 19:09:33
that sounds good. I'm in jersey so shipping is best. how do you what payment?
8Nr--WI
12-28-2012 19:15:13
 Re: dearborn front plow in reply to wrenchtech, 12-28-2012 19:09:33
Doug, I will dig it out of the garage and send you a pic of it tomorrow via email with additional info.....
Tim
wrenchtech
12-28-2012 19:24:08
 Re: dearborn front plow in reply to 8Nr--WI, 12-28-2012 19:15:13
that's great tim.thanks
doug
